Charmilles D10 Isolpulse Switch
Likes Likes:  0
Results 1 to 7 of 7
    Jun 2015
    Arizona
    52
    Default Charmilles D10 Isolpulse Switch
    AL ost up and running hopefully. I need a switch for the ram up down switch. Plastic inside the front part of the switch is trashed. Anybody have one or a source. The switch is two parts whereas the rotating knob cams on a steel piston which ectuates the actual switch behind the power panel.
    Aug 2002
    Regina, Canada
    2,417
    5
    84
    I assume the switch you want is the big grey one top left
    In attached picture?img_20190714_0618585.jpg. Sorry for bad pic
    Jun 2015
    Arizona
    52
    I am not able to open the top panel as I have to remove allbthevknobsvf om the microfin on the right hand side and so far they defy removal. The switch is one of the smaller black ones just above the larger Grey generator switch.
    Jun 2015
    Arizona
    52
    Long at your Pic it is one under the voltmeter or as depicted left of voltmeter.
    Jun 2015
    Arizona
    52
    png-image.jpghere is the diagram from the manual if it loads
    Jun 2015
    Arizona
    52
    No sir just below or right ov the voltage dial.
    Jun 2015
    Arizona
    52
    Do you have any of the switches for sale?. Also trying to figure out how to get the knob off the microfin unit without breaking them. Can't open the front until I remove them.
