Charmilles RoboFil 310 Programming
DieselMater86
Apr 23, 2015
Murfreesboro, Tennessee
I just moved over to Tool and Die after spending 10 years in Job Shop. I have no issues programming the EDM Wire but I need help with power settings. I use MasterCam 2018 for the Wire machine. In MC it asks for a 3 digit number for power setting, but the EDM uses TEC file like L25A. I just need help figuring out what to do just for power settings so I can start making this machine work for us.
I would just output the NC file (gcode) from Mastercam. You may have to modify the post, or manually edit your code. The charmilles (from everything I know running them for alot of years) are better off using the machines .cmd and .tec files to run the code.
