Hello,
im running a 2005 Robofil 380, and i have problem with RS232. After starting machine there is "PMC W2158: RS232 LINE CHECK TIME DEFAULT", checked cable it seems to be ok, pulled out then putted in some plugs on boards and boards itself, after few times machine started normally. After sunday it constantly starts with this error.
Had same problem back in 2019, replaced "master" card but the error was still on, technician pulled out cable pluged it back in and it worked back then.
Lower red diode is mostly on, sometimes its off, still have error. When its on lower cards (UPR) are off.
Anyne had simillar error? Technician form Charmilles is not sure what it could be, he said we should start with replacing RS232 cable i not sure about it being source of it. Will replace it but have to wait for it.
