Charmilles Roboform 31 ISO programming
Results 1 to 3 of 3
    May 2020
    HUNGARY
    Default Charmilles Roboform 31 ISO programming
    Hello all!
    I have a problem, where my machine is getting error on every line while trying to run the program.
    My file is in .iso extension I started the line with the "%" sign but when I start to write the G codes like "G01x100y100z100c0" I get the error message: "error 207 Command expected G01x10...."
    I tried almost everything but I don't know what command it is expecting.
    Nov 2014
    Florida
    4,520
    1737
    2168
    Quote Originally Posted by XenoBen View Post
    Hello all!
    Maybe decimal points? I don't know the machine, so just a WAG...
    edit: feedrate? not sure how those are programmed on an sinker edm...
    Mar 2019
    UNITED KINGDOM
    207
    40
    Possibly can’t handle a 4 axis position. Have you tried the same movement in 4 lines?
    Also have you looked at the error message page? It may give you the whole error message not half a message then an ellipsis.
    And use a G00 not g01 as a sinker doesn’t need feed rate which a G01 would require.
  4. Likes Laurentian liked this post
