Im looking for some advice on changing to .006 diameter wire from .010 on a Sodick Wire EDM . I have a small job I need to make the switch over for. I have done this before in the past but had some difficulty getting started and would greatly appreciate some advice to make things smoother.
I don't have any info on the type of wire the .006 is due to the label has worn off.
Thank You
Thank You
