Claiming G54 on a Mitsubishi DWC-90G wire EDM
Results 1 to 5 of 5
    Aug 2019
    Ohio
    Default Claiming G54 on a Mitsubishi DWC-90G wire EDM
    We have an old DWC-90G Mits wire EDM that I can not get G54 numbers to take. Have been running it from a G92 start point but would like to run multiple parts. Does anyone know the procedure on how to claim a G54? (In case I'm doing something wrong)Does anyone think it may be a software issue? I'm kind of stumped. I came from a shop that has new Agies so this old machine is new to me. I also can't figure out how to zero out the relative position. We have all the books but I can't find anything in there to help. Any help would be appreciated. Thanks.
    Dec 2012
    California USA
    142
    34
    37
    Quote Originally Posted by joe noftz View Post
    If I remember correctly, resetting twice zeroes out relative...making it kinda volatile in my opinion.
    I remember there was a line necessary something like g90g53x0y0z0 then g54x0y0z0...your mitz book should have the exact code along with examples.
    Aug 2019
    Ohio
    I figured out how to zero out the relative. It has to be on the relative screen and then hit the reset button for X,Y,U and V.
    I think what you're telling me with the G54 is how to call it up in the program. I can't get the numbers to set in the machine.
    Thanks for your response. Will keep working on it.
    Aug 2019
    Ohio
    My mistake, for zeroing out relative position. Need to be on screen that has the relative coordinates on (either main screen with 4 positions on it or the screen with just the relative position on it)and then hit X CB(clear block button)then hit it 3 more times to zero Y,U and V. I still have not figured out how to claim G54 in the machine yet.
    Apr 2010
    Wisconsin
    6,045
    4172
    3693
    You can easily do it from within your program, if need be. I do it all the time when needing to set a temporary WCS for probing routines. You can use G14, G43, & G52 for the process. I use variables that are not going to be used with the wire offsets for storing X & Y positions. Typically any from H5-H10. Otherwise, you can also get to the WCS offsets from that same screen you were in, and set it manually.
  6. Likes joe noftz liked this post
