snapatap
- Apr 24, 2013
- south australia
We are having problems with rapid wear of the lower conductivity plate in our sodick A500. The maintenance graph says that I should get 60 hours out of it before i have to move it to a new section but after about 30 hours it has about a .5-1mm groove worn in it, and I'm pretty sure it is causing frequent wire breakages. I also removed the top conductivity plate and there was barely a mark where the wire was. What could be causing the lower plate to wear so badly? The dies have done about 2000 hours which is recommended replacement time in the book, could worn dies be the problem? Also what should I look for to tell me the dies are worn out? We are using a zinc coated high performance wire would this cause increased wear?
