plastikdreams
- May 31, 2011
- upstate nj
Out of the blue today our mits fa10s starting showing a constant contact. The odd part is that it only shows contact when machining is ON. I can run wire feed and there is no contact, even moving the machine around and pushing the cups and on the wire. Machine was in the process of cutting and had .038 left to go.
I checked:
all the rollers from the back to the front.
The wire chopper is not clogged neither is the feed pipe.
Upper and lower powerfeeders are clear
Diamond guides are clear
Lower head is clear
Tank around the ram and cables are clear
Wire is threaded properly and threads as normal.
Upper head is clear
I've never run across this issue and I'm not sure where else to look other than call mits. At some point in the near future they are supposed to be doing a pm on the machine.
Anyone have any ideas or suggestions?
I checked:
Lower head is clear
Upper head is clear
