tvalen1432
- Nov 21, 2014
- Pomona
I use the same program structure and settings for every program and only tweek them to the different material or size part with no problem......until now. All of a sudden I'm now. As the machine is rough cutting, it will cut for like 3-5 sec, show a brief contact, then cut for a few sec and then contact briefly again, then cut for a few, contact briefly, over and over. It's not the bouncy kind of contact like it wants to cut but hits a wall kind it's more like the pause when you push in a clutch on a car to chance gears. ( If that makes sense LOL).
What would cause this all of a sudden change in reaction to the normal routine BS? Rotated power feeders, cleaned every thing, wire align etc. etc. ect. As I was typing this a light bulb went on to try changing the wire spool. Let you know how it goes.
Tvalen1432
Tvalen1432
