Cut E350 program error
NewToEDM
Oct 26, 2018
Hi
When running a program on the machine it doesn't overwrite the previous program , instead it keeps some parameter from previous program .
for example : - i had a job to cut off some parts from an assembly and i used additional clearance 0.4 and also stop after each cut to remove the part, when i wanted to work another program the previous CLE 0.4 remained and also the machine stopped after each operation to "remove" the part .
- also when i do a job with with 1 cut and than i try to do a job with 3 cuts its the same thing , i have to modify the steps and height also and probably some parameters that i don't know about
Is there a code that resets the parameters so you start new program clean ?
Happy New Year !
I have found that it is better to put cle, 0 at the end of all my programs. Along with any other changes you have to manually make like rotations and mirroring. 350 is a good machine, but for a cnc machine you sure have to do a lot of stuff still manually!!! Lol.
