Cut E350 program error
Results 1 to 3 of 3
    Oct 2018
    GERMANY
    38
    8
    Default Cut E350 program error
    Hi
    When running a program on the machine it doesn't overwrite the previous program , instead it keeps some parameter from previous program .
    for example : - i had a job to cut off some parts from an assembly and i used additional clearance 0.4 and also stop after each cut to remove the part, when i wanted to work another program the previous CLE 0.4 remained and also the machine stopped after each operation to "remove" the part .
    - also when i do a job with with 1 cut and than i try to do a job with 3 cuts its the same thing , i have to modify the steps and height also and probably some parameters that i don't know about
    Is there a code that resets the parameters so you start new program clean ?
    Happy New Year !
    Aug 2010
    New England
    319
    39
    clearance is modal, you have to turn off. in command language it is CLE,0 in g-code it is g10 p16 r0
    Mar 2016
    South Carolina
    81
    14
    I have found that it is better to put cle, 0 at the end of all my programs. Along with any other changes you have to manually make like rotations and mirroring. 350 is a good machine, but for a cnc machine you sure have to do a lot of stuff still manually!!! Lol.
  4. Likes NewToEDM liked this post
