Cutting Titanium with Mits FX 10?
Results 1 to 6 of 6
    Mar 2007
    Belgrade, MT USA
    61
    Default Cutting Titanium with Mits FX 10?
    Any one have a Epack # for cutting 1.25 thick Titanium with a Mits fx10 with .012 wire?
    I do not have any info about cutting titanium in my books and I have to cut some small slots.
    Jun 2002
    CANADA
    British Columbia
    2,726
    2314
    Hi Petergun:
    I've cut a lot of titanium and I've always just used steel settings and modified them as needed to keep from breaking the wire.
    If you need them accurate it's worth making test cuts to fine tune the settings and the offsets.
    If you don't, you can get away nicely with stock steel settings and just open up the gap a bit.
    I've cut 4" Ti6Al4V that way without issues.
    Do be aware that Ti bar stock is often full of stresses and will curl like a banana given half a chance.
    Here's a photo of a slice that was cut from the end of a 2" bar.
    It was programmed perfectly straight.
    Cheers
    Marcus
    www.implant-mechanix.com
    www.vancouverwireedm.com
  3. Likes tvalenzuela1432 liked this post
    Mar 2007
    Belgrade, MT USA
    61
    Thanks for the help
    Oct 2015
    77
    112
    7
    How do you avoid the curling or compensate for possible stress?
    Just curious because I have encountered a similar situation with different material.
    Tvalen1432
    Jan 2020
    Illinois
    6
    I always do a face cut if possible. If your trying to slice something thin and the opposite side has been ground there's a good chance it will curl like a banana. We usually will cut and trim the face then 1 cut it off leaving some grinding stock.
    Oct 2018
    Oregon
    60
    6
    18
    We cut Ti6Al4V nearly every week here in the shop I work at. We use sodick machines. To avoid curling of parts most of the items we cut have been annealed to remove stress.
