Utry2win
- Aug 17, 2011
- Lakeland, FL
Ok, so I will start by saying, I am so green to EDM its not even funny. We recently purchased our first WEDM and I am tasked with learning it. Question I have is, how dirty does the water in your tank get while cutting a part? I am currently running a job out of A572 GR50 material, basically mild steel. 2" thick, about 16 linear inches worth of cut. The water gets so cloudy in just a few minutes that I cannot even see the part anymore. Something I am doing wrong, or normal? The machine fills the tank, and throughout the cutting process it uses the flushing from the heads as the only water source for the entire cut. It overflows back to the tank to be filtered and reused. I see videos on youtube of people cutting parts, even long cuts, and the water stays fairly clear. Is it the material? The wire? Cut parameters? Something else I'm missing?
Machine = Excetek V350G
Wire = .012" hard brass
