I am just setting up this Agie and to clean the dielectric tank I removed the left side tank cover to better get at the tank. There is an approx. 3" flexible hose on the top of it leading up to the burn tank and a flexible aluminum 3" hose coming out of the bottom that goes somewhere, which is my problem. When the tank cover was removed, the alum. flex hose was pulled out of it's location and all I need to know is where it is supposed to go. All I know is that it goes somewhere in the back of the machine. After reading through the manual three times with no luck I came here.
