Is EDM the right choice for removing broken stud?
Results 1 to 7 of 7
    Mar 2019
    Alabama
    9
    Default Is EDM the right choice for removing broken stud?
    I've got this small engine that has a broken stud in the exposed end of the crankshaft. I have made several attempts at removing it but it is hardened and resists drilling and other mechanical means of removal. Is EDM a good choice for removing the stud?
    Will I have to remove the crankshaft from the engine (there is some exposed shaft at the crankcase). Is it expensive? A new engine is about $120.00 (the crankshaft itself is not sold individually).
    Let me know your thoughts. Thank you.
    May 2011
    New Jersey
    2,045
    186
    1135
    I'd get a new engine
    Jan 2013
    Plainfield, Indiana, USA
    1,732
    1310
    925
    Yes, you will have to remove the crankshaft from the engine . . . edm happens under dielectric fluid, which is an oil that becomes gritty with edm'd particles; not good for engines.
    Better to buy a new $120 engine.
    Jun 2008
    Roanoke, VA
    666
    192
    252
    I’ve had very few studs that could not be removed by welding a nut to the top of the stud. If the threads above the stub are messed up, that’s when welding is a lot harder.
  5. Likes jptech, bonestock liked this post
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,125
    990
    588
    Just wait till the next sale (next weekend) and use a coupon and you can get another Predator engine for about $89.
    Sep 2006
    Long Island, New York
    596
    209
    79
    or... Accept the challenge and make yourself a new crankshaft. You can do it!!
    Feb 2014
    MN
    21
    Portable EDM for broken tap/stud removal starts at $1750.00
    Number one stocking supplier for wire and sinker edm consumables
  9. Likes memphisjed liked this post
