Okay, hope I can explain this without getting too wordy. Sinker EDM, also called Plunge, Ram or Conventional EDM. Generally 3 to 4 axis. X and Y are like on a mill, Z would be the quill and C would be the spindle. This type of machine uses either graphite or copper for the electode. Electrode is in the shape of the detail you want to burn into your workpiece. Machine uses a dielectric fluid to keep the atmosphere from the burning area, in sinker EDM this is usually petroleum based. No the spark from the electrode to workpiece will not catch the dielectric oil on fire, dielectric is keeping the atmosphere(oxygen) away form the spark. Advantages to this type of machine, tap a hole in a hardened part, do blind pockets, do fine details on mold inserts, drill holes that were forgot before the part was hardened. Machine come in both Manual and CNC, each one has it special place. CNC is great for when you need to make 100 mold inserts with the same details, with an electrode changer you can run un-attended. We have both in our shop, 2 manual, 2 CNC. One CNC with a 90 station electrode changer robot. Wire EDM Generally 5 axis machines X and Y as on a standard machine. Z is generaly programable for height on and stays set when machine is cutting. U and V axis these correspond to the X and Y axis, and can move independentily allowing you to cut tapers and 3D shapes. By 3D I mean square opening on top of workpiece and round hole on bottom of workpiece, as an example. Instead of dielectric oil these machine use water as the dielectric fluid. This water has been filterd and de-ionized. The electrode in this case is a wire generaly brass, sometimes coated or not. Size ranges from .001 to .012 in diameter, its a one shot use and is discarded after that. Machines are all CNC controled. Some uses for this machine are, cutting openings in plates for dies, stack cutting many parts at one time, die inserts that need angular relief, also carbide is no problen to cut. Machines can cut and thread the wire by themself, great when doing a plate with many openings. Can run a high degree of automation with these machines, nights and weekends. We have 2 of our machines runing over the Thanksgiving weekend unattended. Hope I didn't confuse you too much or get too long winded. Mark
