on the working steps page click the down arrow where it says "main" and select entry, then change the flush "p" to 1 and the power "p" around 28 for both the entry and exit. If the part is thin increase the "ssol" on main,entry and exit settings for a smooth and stable feed rate. You also need the toriods in place if taper is greater than 2 degrees. Looks like your using ,006 wire, check pizza cutter wheel, it should read .20-.15 and draw-off rollers at the back of the machine should be in the .008-.006 postion. hope this helps
