Fanuc A-1ic reverse alarm when using R1 variable tech.
Results 1 to 8 of 8
    Feb 2018
    Michigan
    10
    Default Fanuc A-1ic reverse alarm when using R1 variable tech.
    Not sure what is going on but I use the R1 tech in my A-0ib Wire with no problems at all but when trying to use this in my A-1ic machine it always throws a reverse alarm.
    My pilot hole is plenty big and the wire isn’t making contact with the steel.
    Has anyone found a solution to this issue?
    Thank you in advance!
  2. Likes machtool liked this post
  3. #2
    Sep 2006
    Long Island, New York
    512
    119
    59
    The "short" icon isn't lit up and it just does that?
    Feb 2018
    Michigan
    10
    Correct. No short just Reverse Alarm. The wire is seriously .05 away from any steel.
    Sep 2006
    512
    119
    59
    Without a short condition I'm stumped. I was thinking maybe the R1 tech uses a D that's too large for your entry with cutter comp, but then you would get an interference alarm or something. That's assuming this happens during the first move?
    Why would the path reverse with no short? I'm starting to think parameter or something now...
    Sep 2006
    512
    119
    59
    But of course, the short version is "I don't know"
    Feb 2018
    Michigan
    10
    Yea I am stumped. Tried doing a few different things and nothing seemed to work. Ended up using A1 which is fine but the die sections I was cutting out are just clearance and don’t mean squat.
    I checked through the parameter settings and seen nothing that makes any sense.
    Feb 2018
    Michigan
    10
    Ended up being a ground wire posted incorrectly to the lower head after I rebuilt it. The guys from Methods came by and sent a pic and saw the issue. R1 is working good now.
  9. Likes BillDe liked this post
  10. #8
    May 2010
    Massachusetts
    58
    9
    I made that same mistake once. That one red ground wire. Whoops!
