pmack
Cast Iron
- Jan 16, 2015
- Vinemont, Al
I have a 2000 model Fanuc A-0ic with AWT that I am having an edge-finding issue with. It has always performed edge finding accurately up until Monday.
Most of the time it will repeat within .0001, now it won't repeat within .002 and is sometimes throwing Alarm 67 "Measuring Error".
Has anyone dealt with this before? Suggestions? Details below.
Material: Any I have tried.
Wire:Hard Brass Electro-cut .010 diameter
Guides:New(less than 10 hrs)
Power feed contacts: New 20 hours ago, just cleaned and indexed yesterday.
Resistivity: 5.0
Already tried: Indexed brake wheel, cleaned lower ceramic roller(checked bearings too), checked all bearings for wire rollers(Replaced two bearings-I thought it might be wire flutter), checked pinch rollers, cleaned lower water jet tube, cleaned and re-attached table grounds.
Resistivity: 5.0
