Hi again HelpImLost:
OK if this is the reality of your situation then there will be no harm in taking the initiative yourself and seeing if it gets you fired or not.
First thing to do is to find the power contacts and index them.
I've never driven a Fanuc so I don't know where they are on your machine or how to index them, but you can find them if you have the manual.
If your machine is anything like mine, it's a 15 minute job and of all the things that negatively impact performance, it's one of the big ones.
The second thing to do is to check if the DI system works.
To do that simply, find the conductivity probe and short across the terminals with a screwdriver while the machine is on.
If your conductivity gauge reads resistivity it should drop to zero and the DI pump should turn on.
If it reads conductivity, it should rise to infinity. (and the DI pump should turn on)
(Not all machines read the water condition the same way so the reading will change accordingly).
Next, assuming your Dickhead Boss actually has resin in stock, change the resin.
Your conductivity meter will tell you if it can still maintain the proper DI water conditions; the key here is to see if it changes when you cut anything.
Take a chunk of scrap anything and do a test cut to see what happens to the water conductivity when you load it with ions from the cutting process. (or just piss in the water tank, but that's kinda frowned upon
If the DI system turns on and runs continuously and your conductivity is still going up, your resin is shot.
BTW sweat the filters less; many machines will shut down if the filter pressure goes up too high and will force the issue for you.
Also if you overpressure them and blow them out you won't be able to keep the water even remotely clean and it'll become so obvious even Fucknuts will have to concede it's not gonna work.
Next, stick your finger in the worktank a few times during your next longish cut.
If the water is getting warmer your chiller is fucked.
Next do whatever you have to do to keep from getting so many wire breaks.
At the control, there will be settings you can modify on the fly.
When I have a bitchy job to get through the first thing I do is turn down the nominal feed rate. (note that on a wire EDM, the actual feedrate is governed by the feedback loop of the gap voltage; the sensing circuits will override the nominal feedrate in response to that voltage to keep the gap the correct width for sparking and flushing)
Turning down the nominal feedrate makes the gap easier for the machine to maintain.
Next I turn down the ON time and on my machine the "auxiliary ON time".
Next I turn down the wire tension a bit, I turn up the wire speed a bit and I open the servo gap which changes the threshold voltage at which a spark will be triggered and thereby will trigger a spark across a bigger gap, improving the flushing, but FUCKING UP YOUR SIZE CONTROL so watch it if you have to hit a precision target.
Between all these adjustments you can often get the machine to behave acceptably with regard to wire breaks but at the cost of size control and cut speed.
Once you jigger the settings, all bets are off on what you'll get so if in doubt, leave a bit extra on the roughing pass, expect to have to take more skims and expect to have to measure your developing part and sneak up on the size.
So this whole fuckaround violates a basic thing about wire EDM, and that is, if all settings are kept nominal and the machine is in good condition, you can expect consistency within a fraction of a tenth, but as soon as you dump the nominal settings to make it go, you throw all that out the window.
It's always cheaper to keep the machine in good condition; it cuts better, it holds size better, and you can spend the time you'd waste re-threading actually doing what the machine is supposed to be doing.
But if the Boss Man is too stupid to understand that....well it's HIS money going in the toilet after all...so Fuckim, do your shit the best you can and start looking for a better gig.
Cheers
Marcus
