conceptdevelopers
Cast Iron
- Jun 16, 2007
- Garland TX
Still tying to resurrect this machine. Been down 7 years. Thought I had everything going fine and now it doesn't read G54. In case I missed something being away from this for so long, here's how I set it up.I went to the "work piece set-up" screen then to work offsets. I entered the figures in the G54 and hit input. Then I ran G0 G54 X0.0 Y0.0. and it doesn't go anywhere. I moved the head away a little and did it again. It moved back where it was, not the G54 location. I went to the "monitor" screen and pressed position. The G54 values are all set to Zero and the U and V were where they were before I aligned the machine. Went back to work piece set-up to see if my numbers were still there and they were. It's like it's not reading what I entered. It has a few other little gremlins in it like the hours meter changes it's reading 5 times a second. Am I just making a stupid mistake or could there be something wrong in the operating system?
