Thread: General Settings for Hole Popper
10-28-2020, 08:47 AM #1
I am fairly new to EDM. At my shop we have a small hole popper for doing start holes for our wire EDM. I am looking for some help in what settings to play with for optimizing speed vs electrode wear. Currently we are getting 300% or more wear on the electrodes. I have messed with T-on/T-off and V-Gap, but have not had much luck. The manual for the machine does not contain much useful information.
A nudge in the right direction would be very helpful.
10-28-2020, 10:40 AM #2
1mm brass tube T on 10 t off 25 ip9 45 volt 13 amp 50% wear
1.5 mm brass tube T on 15 t off 20 Ip 9 45 volt 15 amp 30% wear
2mm brass tube T on 30 t off 15 Ip 9 40 volt 19 amp 30% wear
Out of our manual.
Tried to scan a few pages, but file to large to attach here.
10-29-2020, 01:54 AM #3
We do a lot of 0.8 holes in 80mm thick steel, 70% wear is absolutely normal.
10-29-2020, 07:58 AM #4
10-29-2020, 08:04 AM #5
10-31-2020, 02:56 PM #6
If you fed in 9 inch to cut 3 inch that’s going to be 200% wear.
As feeding in 3 inch to cut 3 inch would be 0%.
pb1 liked this post
