Inexpensive EDM "Tap blasters" - Anyone have one, any experiences ??
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Sep 2018
    Maryland
    11
    Default Inexpensive EDM "Tap blasters" - Anyone have one, any experiences ??
    Hey guys,
    I was not sure if this was the correct forum but here goes. I have been looking at reasonably priced EDM tap removers such as this one:
    US Stock Portable EDM Broken Tap Extractor Machine EDM-8C Metal Disintegrator | eBay
    My main use for it will be removing steel ball oil galley plugs in automotive cylinder heads. Also for removing broken bolts and studs from heads. The oil galley plugs are typically about 3/8" diameter and are extremely hard. Very similar to ball bearings. I have attached a picture of the type of plug I am dealing with.
    Thanks for any advice,
    Bill
    Feb 2014
    MN
    62
    14
    we supply 3 different models of these and are USA based for support.
    contact [email protected]
    website - Number one stocking supplier for wire and sinker edm consumables
    Feb 2014
    MN
    62
    14
    TR100 Broken Tap Remover
    Aug 2005
    Tucson AZ
    6,705
    10729
    3213
    Quote Originally Posted by Engineshop View Post
    Hey guys,
    Bill
    If I'm seein what I'm seein then the balls are retained by swaging the edges of the hole to hold it in. The EDM tap and drill removers work by burning a hole that encompasses the web of the tap or drill allowing the remaining material to be fractured and removed. It appears that this will leave you with a ball with a hole in it still retained by that swaged rim.
  5. Likes pb1, bryan_machine, TeachMePlease liked this post
    Jan 2020
    Connecticut
    49
    58
    16
    I was going to reply with the same points tdmidget pointed out. Perhaps if the hole you burn through is large enough you'll be able to break the ball up and pull the pieces out.
    Sep 2018
    Maryland
    11
    Quote Originally Posted by tdmidget View Post
    Actually they are not swedged. They just press the balls in and supposedly it deforms the aluminum enough that they stay there. I have taken a couple out a while back by grinding them with a diamond bit in a Dremel tool but it took forever. On those I just tapped the hole for a 1/8" npt plug to seal them back up.
    What I was hoping the edm tool would do is pretty much burn the entire ball out. There is easily enough material left to tap the hole. I am fairly sure it would work ok.
    My main reason for the post was to see how the less expensive machines actually work as compared to an Electro Arc machine which is pretty much out of my price range.
    Sep 2018
    Maryland
    11
    Quote Originally Posted by jyd12f View Post
    Based on my pictures, which one of your machines would you recommend ?
  9. #8
    Mar 2009
    Brunswick Oh USA
    4,728
    5525
    2871
    I own a Cammann Mfg. disintegrator which will be warp speed faster than the one you're picturing. Of course mine weighs 750 pounds. The transformer is as big as that entire Chinese job. I paid $400 for it....working. There's one (same as mine) on ebay for too much money and looks somewhat butchered. Electro-arcs are damn nice as well. There's one of them on ebay as well. Might be worth a look.
    Electro-Arc Model 1SQT Metal Disintegrator Bolt & Tap Remover 440v | eBay
    I only know of those Chinese jobs and have heard they are almost powerless. Would like to see a real video of it operating.
  10. Likes dalmatiangirl61, Engineshop liked this post
  11. #9
    Sep 2018
    Maryland
    11
    Quote Originally Posted by Ray Behner View Post
    And that is exactly why I made this post. I have been looking at the Electro Arcs too. Most of the decent ones on Ebay are all 440 volt for some reason. There are a couple on there right now but are either missing parts or broken, at least the ones in a decent price range I can afford.
  12. #10
    Virginia
    19,015
    7561
    11663
    MONEY is the limiter? When, ever, was it NOT?
    How much TIME do you have? And how OFTEN do you have the need?
    Before ANY of this electric s**t even existed, Old OLD OLD Skewl mentors would have us go retreive a tiny bottle of... ta da... Nitric Acid .. with an eyedropper stopper.. and the ignorant wax to protect whatever it was we did NOT want et through. Storage space was smaller than a half-gallon of milk.
    Wasn't fast. WAS effective. Very.
    Cheap, too. Very.
    Even "not FAST" could be same-day. Not a whole week.
    Basque, Persians, Egyptians, Phoenicians, Scythians, Keltoi (Romans included..) .. ancient Hindu, Tamil, Koreans, Japanese.. Chinese (is there any OTHER kind?) used this s**t long before they knew WHY it worked ... or even what it really WAS! Egypt sent scouts out by water to gather special gravels from the alluvium of some of Africa's great rivers. Didn't know what natural "industrial" Diamond WAS. Only that it worked.
    Guess yah could class the lot of 'em as "Practical" machinashits.. even if a mite "previous" as to getting ahead of their times?
    Run with .... whatever yah can get your ever-impoverished hands on!
    So I still have.. more than just the one type of acid. DO have a care as to what gets in what what ELSE, wilyah?
    I did say OLD Skewl?
    Cheapskate, Iyam!
  13. #11
    Mar 2012
    Geilenkirchen, Germany
    2,791
    1594
    1454
    I have an old German one that I bought used from a friend for 100 Euro. It works very well. It is a box that is about 12" x 16" x 20" and weighs around 35 lbs. It is 220 volts. This box connects to 4" diameter device that mounts in a drill press chuck or equivalent The box has a connection for a garden water hose. The box provides both water and power to this head. On the end of the head is a collet that accepts a copper tube. This thing makes a mess, so I use a junk drill press That I leave outside in my driveway under a cover, but it works very well.
  14. #12
    Jan 2020
    Connecticut
    49
    58
    16
    At the 5 o'clock position on both of those holes it looks like the OEM use a punch to move the material enough to retain them.
  15. #13
    Feb 2019
    New York
    426
    399
    There's a 220v Electro Arc at HGR for $540. You run the risk that it doesn't work, but it's cheap enough to take a chance and in the end at least you have a quality product worthy and capable of being fixed not some wang-chung thing
  16. Likes digger doug, tdmidget liked this post
  17. #14
    Oct 2005
    21,132
    buy-a-xformer....simple single phase unit, not very expensive.
  18. #15
    Oct 2005
    21,132
    if your going to spam, please include the prices.....
  19. #16
    Feb 2014
    MN
    62
    14
    answering a question is not spamming, you can click on the website or email for more information. we have supplied over 200 of these to shops and they work for broken tap removal.
  20. #17
    Feb 2014
    MN
    62
    14
    Are the parts small enough to ship via UPS?
    ship one to me and i will test cut it.
    [email protected]
  21. #18
    Sep 2018
    Maryland
    11
    Quote Originally Posted by pb1 View Post
    I am not sure what those marks are but out of the 8 balls in two cylinder heads they are the only ones.
  22. #19
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,741
    2837
    1748
    So, how long does it take to burn out a 1/4" tap 1/2" deep?
  23. #20
    Jun 2006
    Near Seattle
    5,212
    3794
    1567
    Digger - what is "a-xformer"?
