Installation wiring for Mits 1200
Likes Likes:  0
Results 1 to 1 of 1
    Sep 2009
    PA
    1,478
    193
    414
    Default Installation wiring for Mits 1200
    I was wondering if someone could share how the wired the power supply on a their Wire EDM.
    The mits 1200 we bought has a power supply on wheels so it can be moved out of the way. They said it would run on a 50amp circut. I have a 50amp breaker and some #8THHN I was planning to use. THHN is rated at 55amps. They recommended that I use something flexable so the cabinet can be rolled a little to facilitate servicing the machine.
    I was considering something like SOOW however from what I can find #8 is only rated from 35 amps.
    Only other thing I can think of is to use LiquidTight Flexible metal couduit.
    Any suggestions??
    Thank you.
