wireman08
- Nov 16, 2017
- Newport News Va
Question:
What do you set the K (conductivity) value on Agie Wire machine?
I have a Agie Classic 3. Got it used less than a year ago. The K was set to 10.
K can be set to values from 1-200 with 1 = 1uS/cm.
Reason for question:
I changed my resin at the beginning of a job.
At the beginning of the cut my K was around 27. As the job progressed the K value was slowly returning to a normal setting of 10. As the K dropped I began to have wire breaks and had to lower the power settings, thus slower cut rate.
Not sure if it was related or coincidence.
Has anyone experimented with this setting?
I was cutting mild Steel with no changes in height or flush.
