Maximum Arc Radius
Results 1 to 5 of 5
    Dec 2015
    Ohio
    44
    13
    14
    Default Maximum Arc Radius
    Does anyone happen to know the maximum arc size that Mitsubishi MV or A machines can handle? My software stops at R393.7 I need quite a bit larger. When I post larger it turns to segments(which i cannot have). Using Vero/peps
    Oct 2010
    Oregon
    4,319
    2925
    1438
    Ultimately, it's all segments. If your post cannot be told to break a large radius into sufficiently small segments, you may have to go back into CAD and break the arc into a series of very short ones, basically doing the post processor's work for it.
  3. Likes msrbl liked this post
    May 2005
    296
    241
    9
    Use IJ instead of R? Just a thought. Otherwise, what sfriedberg said. You say you can't have that, but if you tell it what the approximation error in the cusp height can be, you'll get it smooth enough for whatever the application might be. It will be a looooong program.
    Apr 2008
    Auburn Hills, MI
    228
    29
    46
    Jim7511,
    Sounds like you are hitting a software limitation of the machine in terms of the maximum radius size. Have you called Mits about this (maybe there is a parameter that can be changed to help prevent the error)? If you cannot modify or change the geometry, there might be another way to "cheat" this. You can process the geometry as a 4-Axis program using the same geometry for the Top and Bottom profiles (no taper will be machined). This will output a giant program with all small G1 X__ Y__ segments, but might be an easy work-around for your problem.
    -Brian
    Dec 2015
    Ohio
    44
    13
    14
    Ok, so I ended up modifying our cad software.. it was limited to 999.99mm radius output. Just added another 9 in the post code for max arc size and it worked!! The Mitsubishi MV machines can handle a 9999.99mm arc maxium(i&j).
    Customer did not want segments due to the die having .002 cutting clearance.
    Thank you all for the help.
  7. Likes roysol liked this post
