Wade C
Stainless
- Jul 21, 2004
- Wiggins CO. USA
Running a previously proven program, 3 fixtures that hold 4 parts each, using a sub-program for each identical part - and it has just started stopping out of the blue. First two ran fine, third (of 4 on fixture 1) stopped with a Sequence Error alarm. Turn on Flushing, then wire, then machining, and press start, and it picks right back up and finishes the part. Finishes the 4th part on Fixture 1 and moves to Fixture 2.
On fixture 2, first part it stops again, sequence error again, Flush, wire, machining, start, and away she goes, finishes part, and then runs part 2 and 3... On part 4, it stops again, same error - appx same place as previous stops - restart, finishes that line of code, and gets 3/4 of the way through the next line and stops again. Again, sequence error. start it back up, and finishes the part. And then moves to Fixture 3.
So far, on fixture three, I have had to restart it (turn on Flushing, Wire Feed, Machining, press start) on every part, and at least 2 times per part, sometimes 3... and I still have one more part to get through...
It has always been in the same basic spots... in the middle of executing the line its on, on one of the last three lines (two G3 arcs and a G1 G40 move). Never had to mess with it anywhere else in the program (about 8 lines worth for the profile). Threads and starts the next part just fine. Parts that come off are just fine other than you can see where it was restarted (but does not effect the part - so its not trashing parts).
My gut says - system reinstall... and Ill be honest, I have never done it (had the machine running since early 2014), and I know I should do it, but honestly, Im quite nervous about it... I have more disks than I think I need, some look similar but different revisions maybe? All in all, Im probably just being chicken... but I thought I would post up here and see if it sounded like it might be something other than needing a reinstall of software (was going to change the battery at what ever time I do the software).
Maybe someone is bored and wouldnt mind walking me through the reinstall or potential pitfalls that might be inherent to the process? Something to ease my nerves before I jump in and try it?
When the tech was here a couple years ago, he backed up the back lash and pitch error via RS232 but no idea how he did it. I also have a disk that has the current BL and PE that I have out put onto it. And I do know how, and have, backed up all the Epaks and programs on the machine via RS232 so have those backed up. Are there parameters that need reset (that I will have to chase down and note before it happens) or anything like that? Or other info I need to retain from the system as it sits presently - prior to reinstall?
Im probably making a mountain out of a mole here, but with the cost and down time for a service call, my own lack of knowledge scares me in situations like this. I should prolly just grow a bigger set and jump in...
Wade
Wade
