tvalenzuela1432
- Oct 19, 2015
- Ontario, California
Hello all. Ok, I was cleaning the water level sensors on the back of the upper head as well as the black float behind the little box when the clip and float fell off. I put back the float and then put clip back on as well and now I get this alarm that basically wont let me do anything except manually move the head around. It says to adjust the head so its not submerged but there is no water in the work tank to adjust because it wont let any in. I tried shutting all the way down, having the work tank door closed, making sure the sensor was dry before trying to start machine..... Nothing will reset the alarm to where I can make water go in the tank. It will make a clunk noise but no water flow. I don't know if maybe there is something else going on unrelated to the float falling off or what.
Any suggestions?????
Tvalen1432
