Mits FX20k door problems
Likes Likes:  0
Results 1 to 7 of 7
    Jun 2007
    316
    149
    96
    Default Mits FX20k door problems
    This is a great machine but the door drives me crazy. We had a bad seal on it and it kept leaking. got that fixed and all was well, for a while. Next the door wouldn't lower, but it held water. It wouldn't even go down when you hit the e-stop to shut the machine off. over the weekend sometimes it would lower. Then this morning I go to start it and it won't stay up. Usually when it gets all the way up you can hear air escaping for a second or two as the door seals. Now it makes no sound at all at the top. It stays up for a couple seconds then lowers with an alert, "U823 door clamp error". Might anyone have a solution? I really need to get this thing running today
    May 2011
    New Jersey
    2,550
    230
    1370
    Bad door switch. Had it happen before.
    Jun 2007
    316
    149
    96
    Where is this door switch?
    May 2011
    New Jersey
    2,550
    230
    1370
    Not sure, the manufacturers rep did the replacement.
    Jul 2020
    SPAIN
    30
    5
    Hi Cast Iron
    This error could happen for several reasons, one of them could be the switch for door up and down, also machine has in the right side a switch that must be adjusted in order to give the signal to the pneumatic valves that are placed just down on the right side too behind a cover. Valves can be activated manually pressing the small green button, maybe this could help you to make the job for today. Also make sure the microswitches on both pistons are activated, otherwise anything will work.
    Best Regards.
    Jul 2020
    UNITED KINGDOM
    5
    A bit off topic
    Does anyone have the pin connection diagram for the rs232 interface.I have the machine end but i am looking for a 9 pin configaration pc end.
    Regards
    Jul 2020
    SPAIN
    30
    5
    Hi ZIMMYB,
    Maybe I could find something in my info, but is not better to buy a new one?
    Regards.
