Mits fx20k error has me stumped "P153 compensation err"
Results 1 to 3 of 3
    Jun 2007
    324
    149
    96
    Default Mits fx20k error has me stumped "P153 compensation err"
    I am having problems cutting a taper with land. I'm using Bobcad to program. I can run this program without the taper and it goes through just fine. When I run "program check" on the EDM it finds no problems. When I go to "monitor", enter the program # and push start the error come up. I have attached a .TXT file of the simple and short program. I hope someone can tell me what I'm over looking
    Attached Files Attached Files
    Dec 2015
    Ohio
    92
    31
    32
    L100 / STATION 1 DIE BLOCK DIE LIFE(AUTOSAVED)-MAIN-RUN
    (MACHINE,MITSUBISHI,FA,Series,)
    (CREATED-MON.,08/10/2020,09:36AM,)
    N0001 M122
    N0002 G90 G00 X.0019 Y0.
    N0003 G92 X.0019 Y0.
    N0004 M20 M78
    N0005 M80 M82 M84
    N0006 E1251
    N0007 H1=.0068 <--------------------------------------------------------------
    (FEATURE,EDM,2X,INSIDE,2,AXIS,ROUGH,CUT,FORWARD)
    N0008 G01 G41 X.0989 Y-.0242 H1 F.16 M90
    N0009 G03 X.13 Y0. I.0061 J.0243 <-------------------------------------------
    N0010 G03 X-.13 Y0. I-.13 J0.
    N0011 G03 X.13 Y0. I.13 J0.
    N0012 G03 X.0989 Y.0243 I-.025 J0.
    N0013 G01 G40 X.0019 Y0. M91
    N0014 E1251
    N0015 H1=.0068
    (FEATURE,EDM,2X,INSIDE,2,AXIS,ROUGH,CUT,1,FORWARD)
    N0016 G01 G41 X.0989 Y-.0242 AH102 H1 F.16 M90
    N0017 G03 X.13 Y0. I.0061 J.0243
    N0018 G03 X-.13 Y0. I-.13 J0.
    N0019 G03 X.13 Y0. I.13 J0.
    N0020 G03 X.0989 Y.0243 I-.025 J0.
    N0021 G01 G40 X.0019 Y0. G50 M91
    N0022 M00
    N0023 M21
    N0024 M02
    If you are able to without messing up the detail change your offset to .0061 or adjust that radius to sharp.
    You can also turn off compensation error checking in the switch screen.
  3. Likes tvalenzuela1432 liked this post
    Jun 2007
    324
    149
    96
    Thanks much
