irontoys
- Jul 21, 2004
- Louisville, Ky
Just inherited a couple of older mitsu wire edm's when company retired all the tool makers in a cost saving purge. Documentation is almost non existant.Trying to set up DWC 90G machine. In manual mode, I should be able to turn on wire and water. No movement on wire or water from either pendant control, or at main panel. X and y axis move fine. I have an error message that will not go away.
"702 Wrong with sp-resis control." I can reset at panel, alarm condition will go away, then reappear when I try to start flush. I found and cleaned what I believe to be the resistivity probe in the water tank. Still error. I thought that if I could circulate the water through the filters, my water problem would go away. Help!
