Mitsubishi FX-10 1997, Room temperature detection sensor
Jeff247
Oct 29, 2019
Hi, I need a temperature sensor for my FX-10 1997(Room). Do you know if any buy on Amazon or Ebay can do?
Thank you
no, the external one. The problem is that my chiller is overheating. The compressor works all the time because the difference between the water temperature and the ambient temperature is too big. I can see on the digital screen +9.9 degrees Celcius and I should see +0.1..+ 0.2...You don’t have that on your machine?
There are 3 sensors visible from outside, one in water (lower part of chiller), the second one ambient air sensor in chiller (top, visible in mesh near display) and the external one which is attached to the machine body.
I can measure resistance and maybe you can find similar one.
I am clearly missing the one that is attached to the end of this wire (see photo). And yes if possible I would like to have the resistance of this sensor.
Example: 20 degrees celcius = 10 ohm
Hi Satsun,
I’m trying to get answers from Mike from jestertechnologies by phone or email and I don’t have any answers. He does not call back or email..... does he always offer a service? Thank you
