Mitsubishi FX 10 Contact Alarm
Results 1 to 8 of 8
    Mar 2007
    Belgrade, MT USA
    58
    Default Mitsubishi FX 10 Contact Alarm
    I am having a Contact Alarm problem with my FX 10. When i try to center position I get a contact alarm when it is not touching any thing. I even get the alarm with out a part in the machine. I have followed the wire from the spool to the cutting area and can not find the problem . I have also checked the wire to the chopper with no luck. I have had this problem for some time but it is getting worse to the point of not being able to use the machine. The contact light is on in all the time the wire is on but not when it is working as it should. It is also on in the edge finding and alining modes. Hope some one can offer some help. Thanks
    Aug 2006
    greensboro,northcarolina
    2,343
    140
    549
    Time for a thorough cleaning? How can you even start cutting when you have a contact alarm? Look carefully inside the lower housing that secures the power contactor. Any suspicious erosion inside where the contactor is actually held? Either that or you have a sliver of wire somewhere that's hiding from you.
    Dec 2015
    Ohio
    79
    30
    22
    Assuming you know this but...
    How are the resin levels? Is the probe clean that measures this? High levels can cause a false contact.
    If that is ok I would take the spool of wire off the machine, tape up the sensor arms that see if you have wire and turn on wire feed at the control or pendant to see if you still have contact.
    A board might be going out as well.
    Mar 2007
    Belgrade, MT USA
    58
    The resin level caused the false contact. Thanks to both of you for your answers.
    Nov 2014
    Florida
    3,658
    1519
    1732
    Quote Originally Posted by Petergun View Post
    EIther the Mits is way more sensitive (or has better equipment in general) than a Charmilles, or it had to be thru the roof!*
    *assuming we are talking same thing ie water conductivity/resistance if not..
    carry on
    Dec 2015
    Ohio
    79
    30
    22
    Yes, that is what I was referring to.
    Jun 2004
    Idaho
    263
    165
    53
    Proper maintenance is key to WEDM. No maintenance, no machining.
  8. Likes tvalenzuela1432 liked this post
  9. #8
    Oct 2019
    UNITED KINGDOM
    I'd check the grounding wire to the bottom head. These coax style cables flex and will fray over time. If they break and contact the head the alarm will ring constantly.
