tvalenzuela1432
- Oct 19, 2015
- Ontario, California
I'm having issues with my wire cutter motor cutting out intermittently and need a quick fix. I know some people run it with out the cutter and just let it go into the bucket. My question is Can you by pass the cutter and sensors if my machine normally uses one? I need to keep running the machine and fear it might be more than the cutter motor that's wrong. For some reason the cutter blades I put in are hitting the piece they cut against too. Cant figure out why though. So I'm wondering what I have to do to make it work? Can I just remove the cutter part and the wire fall into bucket? Any suggestions would be nice.
Thank You,
Tvalen1432
Thank You,
Tvalen1432
