Mitsubishi FX20K Skimming issues
Results 1 to 6 of 6
    Oct 2019
    UNITED KINGDOM
    Unhappy Mitsubishi FX20K Skimming issues
    Morning all,
    We have some major issues during the 3rd and 4th skims on our FX20K.
    These skims are always dead slow, way less than the FA value. Sometimes even dropping to 0, then speeding up for a second before dropping again no mater what plate thickness we cut.
    I realise the machine is getting on in years but this issue has only really started to appear over the last year or so. And the type of jobs we do havent changed.
    The epacks were (when it ran well) and are still the standard ones from the manual so i dont see why i should have to change them.
    Any suggestions?
    Lee
    May 2011
    New Jersey
    2,632
    248
    1416
    Pm should be off as well as adaptive control. How much are you leaving for a skim, what material, and how tall?
  3. Likes Bud Guitrau liked this post
    May 2006
    98
    33
    44
    Quote Originally Posted by plastikdreams View Post
    I agree with plastikdreams... when skimming (for Mit's users), try turning off your Power Master and Adaptive Control options and I offer the same advice for any-and-all wire machines that have similar adaptive features.
    While these options are advantageous in roughing and bad-flush conditions, skimming is usually much less problematic and IMHO, these "thinking" options can interfere with the simplicity of skim-cuts and instead, allow the machine the opportunity to "outsmart" or even "argue" with itself ("Uh oh... slow down. Oh no... a sharp corner. Oh no... too much material left in a fillet, what'a we do now? Hey, we've got 2" of straight cutting, let's speed up.") Umm... no thanks.
    IMO, most skim cuts are quite straight-forward and simplistic and don't need a "conversation" among multiple, algorithmic "gremlins", all cranking handles within the control.
    Since I've been wrong before, I ask any OEM apps-guys who frequent this venue; if you have a better explanation or strategy for skim cutting, straighten me out on this as I don't wanna short-change your product's abilities or speak in error.
    BG
  5. Likes WRL liked this post
  6. #4
    Oct 2019
    UNITED KINGDOM
    Thanks for all the replies guys.
    Looks like i'll try without adaptive and pm, though, honestly, they have always been turned on on all the cuts ive done over previous years. It seems odd i have to change things like that now.
    FYI material is either hard 01 or hard D2 toolsteels ranging from 20 to 90mm thick. The problems occur on every thickness unless we use e-packs for thicker material (eg 30mm steel needs 40 thick e-packs). The only problem in doing this is that we are having sizing issues. Everything cuts too tight / small.
  7. #5
    Dec 2015
    Ohio
    92
    31
    32
    I just had a similar issue on a MV2400 except mine would slow to a stop on the 2nd skim. Turned out to be a cable to the lower head was bad. Might want to check for continuity.
  8. #6
    Jul 2020
    SPAIN
    51
    8
    Hi Lee,
    Just small question, rough cut goes ok?
    If that so check the water pressure for skim it should be around 1 on the flowmeter, another point very important is the water quality, please check it is on 24 and if you could measure with device for microSiemens it should go around 15 microSiemens measuring directly on the clean water tank. Clean the resistivity sensor before measuring.Give new position on power feeders upper and lower and if DD guides has a lot of hours please change them.
    If the problem persist please check the offset values, for the 3rd and 4rth skims maybe the wire find so much material to do the skim cut. in order to solve this depending on what you're doing punch or die, in punch reduce the offset and remember it is radial, for die do the reverse higher the offset, but only in rough cut and 1st and 2nd skim and leave the 3rd and the 4rth to the original values. The point is to make the increment a litle bit soft, also ckeck the water flow in the rough that should be strong, around 10 put your finger while fluid on trying to cut the flow if you're able to do it the water pump is not OK andyour problem comes from the first cut on the water flow part.
    Best regards.
