Hello everyone!
My shop has a MV2400R and out of no where we are getting the errors, "U730-T730 T/C IN FLUID", as well as Axis interlock. We've gotten the problem located to the 3 pin sensor on the right side of the top head. We even went as far as replacing the sensor but still no luck. The error isn't constant but when it does happen it takes multiple attempts to get the machine started up again. The water resistivity is in the green, and we are cleaning the pins with a non abrasive alkaline cleaner and a tooth brush (as per the manuals recommendations). Though the same results seem to ensue, it runs for a bit then the error comes up again and again. Any help would be greatly appreciated!
