Hi, possibly your problem comes form generator. Some PCB could be broken.
One simple test that you can perform is to enter a technology with IP higher than 4, and press fluid-wire-machining if there's contact try to input a technology with Ip 3 or lower. With Ip3 or lower is working sub unit so if there's no contact probably your problem is on the main units.
Let me know, best Regards.
