Mitsubishi wire EDM CX20
Likes Likes:  0
Results 1 to 4 of 4
    Sep 2016
    36
    Default Mitsubishi wire EDM CX20
    Problem with Contact On alarm as soon as machining is activated manually or by program What could be potential solution. ?
    Sep 2016
    36
    Any feedback.? I disconnect and connected after testing one by one the cables that goes to upper and lower heads. I play with Di water resistivity. No change. Same alarm if contact after M84 (machining) is enable.
    Jul 2020
    SPAIN
    51
    8
    Hi, possibly your problem comes form generator. Some PCB could be broken.
    One simple test that you can perform is to enter a technology with IP higher than 4, and press fluid-wire-machining if there's contact try to input a technology with Ip 3 or lower. With Ip3 or lower is working sub unit so if there's no contact probably your problem is on the main units.
    Let me know, best Regards.
    Sep 2016
    36
    Thank you for your advice. I will try tomorrow and post the result.
