More DWC90C trouble
Likes Likes:  0
Results 1 to 6 of 6
    Apr 2007
    South Carolina
    77
    15
    9
    Default More DWC90C trouble
    OK, I have been having a good time working this machine as much as possible, as a shake down cruise before the MC Mach subscription is up next month, been learning a lot & getting more familiar with the controls, etc.
    Today I went to cut a money job & the machine is alarming a 503 on X. A few weeks ago it had the same issue and Mits recommended swapping axis motor and encoder leads to see if the fault changed to Y or stayed with X. At that time when I swapped cables everything started working except backwards, so I put it back right & cut for many hours with no trouble. It's harder to trouble shoot when it will not stay broken. This time I changed cables again as before & the fault stayed with the X axis. I believe this was supposed to mean that it was a bad drive. I have checked the fuses on the drive and reseated connections on that and also the FX16 board, etc. APUC-10-DWC BY171A449G51 is what the motor cables attach to.
    Question: Is there something else I could check? just pulling my hair out here, I was going to cut a hex that I could have broached, albeit imperfectly, and now the D2 is 60rc & machine down. Really!! yesterday it booted up perfectly
    Sep 2017
    45
    7
    Quote Originally Posted by mymachinery View Post
    Just saying, I have machines with 100K on hours and only 25k burn hours.
    Not that this will "fix" anything. But if it boots up good, do not turn it off.
    Apr 2021
    Virginia
    7
    56
    This exact issue happened to me as well. Ensure that your lower flushing cup is set sub table level. I eyeballed mine when re installing my lower head after cleaning one day and it was about +.005 of the table level. This alarm would randomly occur for me at different times during jobs and luckily a Mitsubishi technician told me to check if my lower flush cup was dragging any. After setting it correctly, the alarm has not occured since.
    I was thinking it was the encoder too and I was sugguested a many of parts to replace until I talked to the right person with an easy fix.
    Good Luck!
    May 2011
    New Jersey
    3,344
    371
    1908
    Maybe this will give some insight
    Mits DWC 90C and 90H problems
    Apr 2007
    South Carolina
    77
    15
    9
    Quote Originally Posted by HS70A Brother View Post
    Yes, I understand the reasoning there. Yesterday evening we got a storm cell right over us that hovered for over an hour with torrential rain & some lighting. I shut it down. It is nothing here for me to go visit a customer a mile away & before I get back it rains & blows into the open rollup door I left open because of the heat. When I moved to SC from CA, it took a while to learn "roll up the car window because sometimes you never can tell when it will rain.
    Apr 2007
    South Carolina
    77
    15
    9
    Yes, I had thread searched for hours & read that one, lots of experience to learn from here. In consultation with my Mits tech, I replaced the servo amp and went back to work, burned until 1am & got the job done. if anyone is keeping count, the Mits price for refurb amp is 4K, then a 25% refund with your acceptable repairable core.
