MV1200S fluid
Results 1 to 12 of 12
Thread: MV1200S fluid
    Oct 2016
    CZECH REPUBLIC
    11
    Default MV1200S fluid
    Hey guys,
    we have recently some problem with our MV1200S machine. When we run some work and its all done, the Fluid is still ON untill we push STOP button or Fluid button. I tried to look into Settings if something could help me, but nothing i guess.
    Its not doing any harm, but its annoyoing when every time my program ends i have to stop that.
    Jun 2016
    HUNGARY
    27
    53
    9
    put M21 (cut wire) before M91.
    Idk if it's a glitch or not, as it does not always leaves fluid on for me on the mv 2400, but cutting the wire fixes it for me.
    the end of my programs look like this
    M21
    M91
    M58
    M121
    M02
    Oct 2016
    CZECH REPUBLIC
    11
    To be honest thats not a solution. When im making 5+ programms per day its gonna be crazy to edit all of them. Im looking for something that will fix that without making some big changes.
    Jan 2017
    Illinois
    19
    Does the MV Series control come with a string editor?
    May 2011
    New Jersey
    2,534
    228
    1362
    We post double m58 and also m81 on our mv's...always fun when you drop the level before you turn off the fluid and it on high lol
  6. Likes tvalenzuela1432 liked this post
    Oct 2016
    CZECH REPUBLIC
    11
    Quote Originally Posted by Sodickguy View Post
    Yes, it does.
    Jan 2017
    Illinois
    19
    If you have a string editor, have you considered using it to implement msrbl's suggestion?
    That is, make "M91" = "M21, M91, M58, M121, M02" if this is possible on your Mits.
  9. #8
    Oct 2015
    100
    131
    11
    In regards to the M91=, I would suggest doing that with the M02 rather than the M91 if that possible. Suppose you don't want to cut wire at the M91 every time?? Just a thought. I have the same problem as you. I have noticed that when I use an M30 it doesn't do that though.
    Tvalen1432
  10. Likes Jim7511 liked this post
  11. #9
    Jun 2013
    Ohio
    29
    5
    5
    Quote Originally Posted by Dodgey View Post
    M81 is fluid off, if I remember right. Just plug that into your post processor, you don't have to manually edit every program.
    if you haven't already, learn to edit your post processor. You're at its' mercy until you do.
    Dan
  12. #10
    Dec 2015
    Ohio
    87
    30
    27
    Quote Originally Posted by msrbl View Post
    M21
    M91
    M58
    M121
    M02
    Mine is set up the same way except I use sub-programs. So our cutting files end with G23 and the main file contains the water and door codes.
  13. #11
    Dec 2012
    UK
    69
    13
    Check and see if FLUID CYCLE is switched on? If yes turn it off, on older machines this kept the flushing on until you turn it off.
  14. #12
    Feb 2006
    New Jersey
    1,420
    7
    49
    Quote Originally Posted by makrep View Post
    This. Also, "DD Cleaning". You will have to go to the Maintenance > Switches pages to find it (turn it off).
  15. Likes Space Wolf liked this post
