Guys, new to the site as a member but have been trolling for a few years.
I am looking at bringing into the shop a used EDM machine and wanting some advice on what the costs would be and any pitfalls to avoid (brands, etc). Currently we go through 3-4 tons of aluminum round bar a month that requires a holes of varying sizes to be cut out of the middle. A good example is the following: 9.5” OD, raw stock with the final dims on the parts at 9.350”OD and 7.5” ID. In this size we will go through 24-36’ of this material each month, cut into 12” pieces. My thought is that I can use a wire EDM to rough out the material and also get a roughly 7.250” piece of material to use for other parts that I need it for anyway. I can also take the material out the middle of that 7.25” part and use it again for other parts that I need to make monthly.
The EDM would need to support 12”x12”x12” material. Speed it not a huge factor since I can put it into the production schedule pretty easily, but being able to run lights out would be a HUGE addition. The machine time and material savings this could offer seem to be significant, especially since we are essentially cutting circles that are not required to be exceptionally accurate.
What would you advise on this? I anticipate that the machine would work 20-30 hrs per week. I am especially needing ideas on running costs, both monthly and annually (such as how much wire would be used to cut the slug out of the 9.5" piece above, and how long it would take, etc).
Thanks for your help with this.
