Need Help! 1993 Fanuc Robocut alarms
Likes Likes:  0
Results 1 to 3 of 3
    Sep 2008
    Dresden, Tn
    84
    Default Need Help! 1993 Fanuc Robocut alarms
    Good morning!
    We bought a 1993 FANUC Robocut Alpha 0a machine with Fanuc 16WA controller a few years ago and are just now getting to powering it up ( long story..). It was running before it was moved as I saw it running. When we power it up now we are getting some errors. When the guy unhooked the wiring he took pictures and marked everything and from what I can tell it is back like it was. The alarms I am getting are
    510 Which the books says it Overload signal for X axis motor
    516 Which the book says is for X axis digital servo detection system
    520 Overload signal for Y axis
    526 Y axis digital servo detection system.
    It also says the the cause is indicated but Alarm 2 for the 510 and 520 errors and Alarm 1 for the 516 and 526 errors.
    I have looked at these and cant really figure it out. I assume that where the 1 is on the Alarms tells what t he cause is but on Alarm 2 the spots where the 1 is don't have anything listed.
    When I bring up the Alarms on the screen here is what I see
    Alarm 1 10000000
    Alarm 2 00101001
    Alarm 3 10000000
    Alarm 4 00000000
    Alarm 5 01100000
    If someone can help me decipher all of this and point me in a direction to start checking things I would appreciate it.
    Aug 2008
    westfield,ma
    38
    Since the machine has been turned off for that long of a time,
    the batteries probably have gone bad. This in turn will cause the
    Fanuc controller to lose it's parameters to operate. Your digital
    servo parameters have to be reloaded. Most machines come with a hard
    copy of the parameters in the controller. In the maintenance manual,
    there is an explanation of how to load parameters and a way to call
    back basic and (I believe) digital servo parameters.
    Sep 2008
    Dresden, Tn
    84
    Quote Originally Posted by jdd View Post
    Thanks! I'll check it ., Yea the batteries were dead when We turned machine on. Had a guy who normally works on mills and lathes look at it since he knows the fanuc controllers and he said it looked like it hadn't lost the parameters but It may have lost some and since he hasn't worked on an EDM might have missed it. I had actually changed the batteries when we got the machine but it had been turned off and that was like 3 yrs ago....
    Appreciate the reply
