snowman
- Jul 31, 2004
- Southeast Michigan
I need to cut complex cavities and holes in a conductive metal.
Sort of hard to explain, but what I want to build is a sinker EDM that works on material as it's moving. Further, it won't work in the simple vertical format that most sinkers are set up in, so I need to be able to move my plunge axis wherever I please.
Problem is, I don't really know much about EDM. I've never worked in a shop that had one.
I understand the rudimentary fundamentals of how the machines work. My initial thought it just to build one, but I don't want any more projects. Realistically though, just the simple RC circuit would probably suffice, but I'm worried about tool geometry holding up. Basically, I want whatever shape is on my graphite to not wear "too much"....and it's my understanding, which may be completely wrong, that the "look ma, I made an EDM" circuit with a transformer, a few capacitors and a resistor will erode my graphite. I will have excellent dielectric fluid flow at the spark gap.
My guess, any technology that has integrated circuits driving it instead of vacuum tubes would probably work fine. Honestly, vacuum tubes would probably work for what I want to do. Precision is NOT necessary, it's all cosmetic work. What is necessary is that it put out the spark whenever it's close enough to spark, and I guess that it also drive the servo (I could honestly probably get by listening to the bacon fry, but again, and please correct me if I'm wrong, I think that when the spark gap varies too much, you end up with erosion of your graphite). The less bells and whistles the better.
So do I buy the whole big giant machine so I can cut a few holes to learn? Or do I just look for a used power supply? How much hair am I likely to pull out trying to get a vintage sparker to spark assuming I hook one lead to the part and the other to the electrode? I'd really prefer single phase if that's reasonable. Material removal rate will not be very large...any machine that can say run a 1/4" diameter graphite through 1/2" in under 20 minutes would probably be more than enough. But again, I'm ignorant to the world of EDM, so I don't even know how reasonable that is.
