SBAER
Hot Rolled
- Aug 21, 2006
- Kitchener, on canada
If I want to make a cut that roughs out a cut followed by a skim cut do I have to add the offset in using my CAM program? I am making the toolpath by cutting and pasting a tool path made in HSM express using a 0.010" cutter and letting the CAM do the tool comp. How much offset is appropriate for 1/4" thick high speed steel?
The Brother manual does not mention anything about offset compensation for rough cuts in the Technology setting part of the manual.
As I understand, the rough cut is done at high flush and the skim cut done at low flush.
