Oscarmax s43os
VictorStefan
Oct 18, 2017
Hello all,
I have a problem while i'm trying to do a hole, with my OSCARMAX S43OS
When i try to erodate, after some minutes, between my electrod and my workpiece surface appear some carbon, and doesnt let me anymore to drill. I removed the carbon, but the carbon appeared again.
My electrode diameter is 2 mm.
It should be something in the settings, to avoid that problem, but i couldnt find it. Maybe you guys know something about this.
The electrode that i use is drilled over the entire lenght, and thats why, i think, i get carbon
Srry for my english
Hello all,
Srry for my english
Hello,
so you are burning 2mm thru hole. Do you use copper electrode with hole inside? If you dont - use one. Make a holder for that electrode and put some hose with edm oil thru on that electrode. It should work.
Best regards, Franc
yes, i use cooper electrode with hole inside. My cooper diameter is 2mm, and the hole distance was 10-15mm. I already use edm oil
