Hi, i am in dispute with our wire programmer. we have 3 Agie Charmilles wire machines 4020, 4030 and a 2020. all 3 are set with fixtures to hold 8 finished turned components which require a wired profile concentric to the outer 82mm dia but we are having concentricity issues. the fixtures are pretty flat and the parts are square. The parts have a different bore dia at each end, 13.1mm and 28.5mm. we currently clock over the top to check flatness, centre find the top 13.1mm dia hole and then by moving to the hole centre he centre finds the 28.5mm hole at the bottom by moving X,Y only. He then splits the difference and sets a datum between the two points and does this for each part then edits the positions in the program. we have 0.03mm concentricty tolerance which rarely comes in and if it does its usually only one end.
The machines are quite old but there must be an easier/more positive way by tilting the wire to allign with the 2 holes. the concentricity of the 2 holes in the turned blanks are within 0.01mm before we start.
I have never had any wire experience with programming wire machines and welcome any ideas or solutions.
