Hi again Kjeksen:
A manual sinker will be as accurate as the ram motion is.
These machines run a ram (which holds the electrode) up and down on a slide and control it with a hydraulic piston and a Moog servo valve on the really old machines, or a ball screw and a stepper motor on the slightly less ancient ones, and a ball screw, a servo motor and driver on the modern ones.
The condition of the ram, the condition of the screw, and crucially the construction of the ram motion system determine how consistently it will point to exactly the same spot every time it goes up and down.
Since it's a cantilevered beam (supported only at one end), any wear in the mechanism affects its accuracy radically.
A good quality new machine should be able to position its ram repeatably within a micron or so at full extension.
My old (1983) Hansvedt SMB 150 (ball bushings on two round posts) couldn't re-position itself within 50 microns any more, and my newer one (vintage 1996) with a ball slide can do about 4 microns at full extension after 25 years of running.
So best case there's almost half of your tolerance taken up just with uncertainty about where the ram actually is compared to where you're pretending it is every time it strokes down to burn.
With jump flushing, it will cycle several times a second and on a linear motor machine several hundred times a second.
Positioning precision on a manual sinker is as good as the Acme screws that position the table together with the yaw, pitch and roll common to all machine tools, especially those with cast iron slides and manual screws.
Again, a good machine with a good readout on it will be reliably able to position within 10 microns but a beater may be miles off.
Thermal effects dominate in this process, and the presence or absence of a chiller (presuming it's working correctly) may influence the precision by an order of magnitude more than positioning precision.
The variability of the sparking process itself depends on the consistency of the generator in its ability to make identical sparks as the electronics warm up and is typically a minor effect.
So realistically speaking the challenge is multi factorial from the point of view of the machine and its condition, but overall, with a manual machine, I'd be most happy if I could produce my job within 25 microns on a typical used manual sinker of vintage 2000 or newer.
On a brand new, super, top of the line Makino, in a climate controlled facility, cost no object, I would be happy to be able to hold 2 microns for position and size assuming my trodes are 10 times better, my trode holder system is 10 times better and my metrology is good enough to interrogate my developing parts in the micron range while still on the machine.
Cheers
Marcus
