mymachinery
- Apr 4, 2007
- McBEE, SC
OK, I have some parts to cut that will need skim cuts, I have been reading the manual about setting the weak flush for the skim, but not sure that my machine is working correctly. The manual has been subject to interpretation before.
I have tried changing the flush on the E-set from 2 (strong) to 1 (weak) and I hear a solenoid click, but the flush doesn't change. As I understand it, I should set the strong setting with the up & down knobs & the flowmeters with the 2 enabled. Then change the setting to 1 and set the weak flow with the single weak knob.
Ideas?? Thanks.
Ideas?? Thanks.
