I have recently purchased on older fx20, and am new to wire cutting. It came with the USB /floppy emulator from Mits. However before I had the machine moved I tried to make a parameters copy. I have a file but can't tell if it's all correct.
I also have the floppy disks for the e-packs and pitch error. I can load the main system software into the controller from the USB but I'm not sure my downloaded file is correct and would like to try to load the floppies. I know that the disk format is CP/M so I can't really read the disk other wise I would just copy to the USB and load it that way.
My question is can I unplug the USB emulator and add a floppy drive in it's place to read the disks? Or is it a propriety floppy as well to read the CP/M format?
Any help would be great
