Resin tank replacement
Likes Likes:  0
Results 1 to 3 of 3
    Aug 2002
    Regina, Canada
    2,361
    5
    77
    Default Resin tank replacement
    I need to replace the tank on my wire machine. I suspect that a "genuine" tank would cost many times what the old machine is worth even if available so I bought this small water softener tank. It is about the the same size as the original but my concern is that the strainer may not be fine enough. Any thoughts?
    Bob
    Aug 2012
    California, Central Coast
    3,958
    2216
    1562
    What does the original strainer look like? Can you use the old strainer in the new tank?
    May 2013
    PA
    89
    38
    18
    We get our tanks through SST. Great program, when needed order the tanks, they send them, put the used tank back in the box and send them back. Cheap too.
